tcruwithme
- 20
- 18
- Eagan, MN
So, I got an MEP-004 from Government Planet about a month ago. It was advertised as non-functional with the problem described as "unit runs only when start/stop switch held in the start position." To me, that sounded like a fixable problem. I won the auction and towed the MEP-004 on the M201 trailer 240 miles home to Minneapolis.
I charged up the batteries, and they held a charge overnight. It turned the starter over, so I thought batteries were good to go. The TM troubleshooting section had this exact problem described. It said to replace relays K1 (Relay, Start-Stop), then if still not working replace relay K2 (Relay, Over-voltage), and then if still not working replace relay K8 (Relay, Fuel Level). At about $50 each relay, I obviously needed all three. The K8 relay was the problem, so those other two were probably fine. Oh, and even though the K1 and K8 relays had different part numbers, they are the exact same thing. Nice.
After the K8 relay was replaced (pain in the ass), the starter would no longer turn over. The batteries were shot. Great.
I replaced the batteries, and now the unit starts and stays running. The convenience outlet is all messed up, but that's an easy and cheap fix. The fuel sending unit doesn't work, so that's another $60. At least I got to order that from Saturn - those cats are pretty cool.
Next weekend I'll replace the sending unit and convenience outlet. At that time, I'll put a load on it and see how it does. Fingers crossed ...
