- 293
- 29
- 28
- Odessa/Texas
So, I bought a MEP-831a from Ebay. Going to be at least a few weeks before it gets here, in the mean time I need run some things by this fourm. The set has 7Hrs on it, has no battery so im needing that. I figure some SLA PS-12180 NB 12V 18AH battery's should work out nicely, way cheaper than trying to find a 24 volt one. I orderd a Solargizer IS-24-L to maintains battery when it outside, also getting a Waterproof Power Battery Tender Plus 24V 2.5A for when it indoors unit might be indoors for up to a year in some situations. I dont want to charge threw the slave port I plan to mount it inside unit, just need to figure out if i want to mount a plug on it for 120VAC for charging maybe an amphenol connector(recommendations on type of connector needed). As for fuel I'm thinking about using the aux fuel line connected to a Scepter fuel can with a (MEP002A-MEP003A-Universal Milspec Bung Adapter and 2 Brass Sections for Aux Fuel Kit) from Green Mountain Generator. Is that compatible with that fuel can?
Any recommendations/corrections would be greatly appreciated, TIA
I also plan to document all progress on this forum.
