71DeuceAK
- 407
- 83
- Fairbanks, Alaska
^Meaning...from a hotrod owner to now being a Deuce owner?
LOL at the idea of a Deuce on a race track...
http://www.steelsoldiers.com/showthread.php?t=55400LOL at the idea of a Deuce on a race track...
Has your truck ever been in a front impact accident ? Or have you ever been off-road and have the truck get twisted really bad ? If yes to either question I would have your frame checked for straightness. A good truck alignment shop can straighten a truck frame very easily. You would be surprised how many trucks are running down our roads with bent frames. When I was working a IHC in Tukwilla, WA. I had to take the trucks down to the alignment shop in Seattle whenever we couldn't fix a steering problem. Almost every single truck had a bent frame ! I had to wait for them to get fixed and drive them back so I would hang out with the guys and see how they straightened the frames. It was really simple and fast and didn't cost all that much either.Had a bit of an issue this weekend. I installed the Ross HF54 a couple of years ago and was surprised to see how darty it got after the mod. I installed 4* shims and that helped, but it was still too darty to be comfortable. I got a used set of spring perches a few months ago and drilled them out for flipping.
I tore into the spring mounts to put in the 'new' perches and found that my axle was off-centered. I spent all of friday evening and saturday morning trying to get it moved over. I ended up sticking the nose into the garage where the floor is polished concrete and smoother. I had to lift the truck by the bumper with the engine hoist (pretty sure I maxed my hoist out), put a car jack under each leaf spring, a racing jack under the pumpkin, I had a car dolly under the d-side tire, and a chain host attached to the garage support and winching the axle towards the p-side. Fortunately that did the trick.
Ultimately the axle went from -4* caster in the original configuration to 0* with the shim to now +4* with the perches reversed. Truck did quite a bit better on the shakedown run, but still not quite as tight as I would like.
I also installed a NOS passenger seat cover. Thanks to @Evil Dr. Porkchop for a good part at a great price and quick shipping.
Also made some progress on my heater installation. A bunch of parts got OD Green in preparation for installation. Just need to figure out where (exactly) in the cab I want to mount the box. Its been shortened 4".
Wanna buy oneWish I had a m109.....I took mine out of the driveway for the first time since I replaced the transmission, clutch, rear main, full interior re-do, and full paint job. Drove good, clutch releases at top of pedal. Think I might need to adjust it some
What kind of trailer is that? I've never seen one like that before.Helped my friend deliver his trailer from Fort Loxahatchee, to his yard. First pic shows his trailer in tow by my Truck 3. Pic three shows the owner of the m108 connecting up to move the trailer. and M108 wrecker...oerator of the crane is Roy the terror..
FPChief has first dibs, but I'll keep you in mind.Depends, how much?
M353 trailer. Designed to hold a MEP generator. Handy/stable unit. Great for liquid tank or a big generator
