Kellyboy
- 0
- 6
- Milton, VT
While trying to diagnose a hard start problem I decided to bypass the glow plug resistors. Before doing so I took a voltage reading on it. I found that it only had 12V feeding it from the first battery in series. I believe it should be fed with 24v (correct me if I'm wrong). The wierd thing is it still has 12v on the down stream side. Pulled it off and checked resistance from end to end and got perfect continuity. It doesn't seem to have been modified in any way (see pic). If the unit was burned up shouldn't there be a dead short or loss of continuity. So confused. Either way the relay is now jumped to the 12v fusible link above it. Should I run a separate line to the front battery or is it fine feeding from the fused terminal?
