LMTV - What's Behind Door Number 2? - Pic & Diagram Behind Heater
Overdrive
96
Wentzville, Missouri
This is just an FYI post to show what it looks like behind the heater and what the major stuff is behind there. I took this in the middle of my Gen2 AC install so there are huge holes that I had to drill in the cab floor that won't be there on a stock truck.
Just in case you were wondering what's behind the heater...
This pic shows the 80mil soundproofing I added under the heater and against the front firewall. If you look closely in this 2nd pic you can see the top of the Charge Air box VERY close to the underside of the cab. Mayor pucker factor drilling out those holes that close to disaster.
Hope this helps somebody.
OD
lmtvjunky
Auburn/California
Wow, so that's what it looks like behind thar! So what are you replacing the heater with, a refrigerator would be awsome if you can find a good fit *_* I've always wanted a fridge front and center!!!
Keith Knight
1,838
Wauchula, FL
Thanks for the preview. Looks like we are all trying to get them installed before the summer heat, as I just started the process. I have plenty of questions. I have a gen 1 AC evap unit and plan to use a humvee / universal kit for the rest of the components.
What are you guys doing for the rest of the components?
What condenser are you using?
Where are you mounting it?
How and where are you mounting the compressor?
Thanks for any advise that you would like to share.
mkcoen
381
Spring Branch, TX
Here's the thread with most of the AC info: http://www.steelsoldiers.com/showthread.php?125132-LMTV-Air-Conditioner
Overdrive
96
I am going to do a write-up separate from the big AC thread specifically for the AC Compressor brackets. What may seem like a simple install involves two CRITICAL components that you have to unbolt, the left engine mount and the air pump/power steering pump combo.
You need to get longer metric bolts and for goodness sake CHECK YOUR ENGINE MOUNT BOLTS RIGHT NOW!!!! During the bracket install BOTH sets of engine mount bolts on my 97' LMTV were scary loose.
OD
mkcoen
381
Spring Branch, TX
During the bracket install BOTH sets of engine mount bolts on my 07' LMTV were scary loose.
'07 or '97? Just curious as that'd change from a 1078 to a 1078A1 (whole different set up). Looking forward to your write up. The wife gave me the green light to go for one so I'm extremely interested.
