Isuzu C240.... a nice industrial engine (generator take outs I believe) that can be used in fork trucks, marine and small trucks. What a great little engine, around 38 hp. I bought one and hope to use it for a small sawmill.
I can't find much on it in the SS search, except as a potential re-power in a CJ and so I thought there could be a thread where other uses and adaptations are explored.
First off, mine has no governor, but does have the injector pump. That's an issue, given the cost of a new VS governor can be way more than the cost of the engine.
I remembered that a trailer I use for storage still had the refer unit and that it was a small four cylinder diesel. It's a Thermo-king, but looks like the C240 Isuzu. Mine seems to have TK in the block and they just put C240 on the other, otherwise it appears just a bit of age separates them.
It has a Kiki governor and injector pump. Both pumps and the portion of the governor that is on the engine seem to be the same (Bosch design) and thus the governor appears that it will fit/change over. I'll post some pictures and go into it further as I go along
Also there is the issue of the power end and I was eyeing the huge oil pan on the Therm-king (TK). The TK runs a compressor directly and has a generator ran by 2 belts off the bottom. Thus the bell housing is different but it appears will bolt right to the back of the C240. I'll post pictures of this too and hope that others will add C240 stuff (from generators) to it.
Anybody else buy one of these?
