After some time on my back under the truck ( '92 M998 ) with a multimeter and the TMs, I've come to the conclusion my fuel sender is bad. That's unfortunate, as taking the fuel tank out looks like a small scale nightmare.
I've read about the fuel tank access cover kit, and ordered some dzus clips and backing plate to make my own. My intention is to carefully mark and cut out the tunnel floor above of the fuel sender, install the dzus clips and backing plates, and the end result is a flush fitting plate that lives under the plywood tunnel cover.
The dzus clips:
For the experts, my first question is: if I'm careful, can I cut the access hatch with the tank in place?
The second question is, how large to make the hatch. I'm limited front-back by the support rails. For width, I found the picture below (bottom towards the front of the truck, birds eye view), and labelled the raised ridges 1,2,3, and 4. I think I can only install the dzus backing plates under the raised ridges where I can slide them under. Should I make the cutout the same size as the picture, or extend it one ridge in either of both direction?
Thanks much all!
The dzus clips:
Thanks much all!
