CUCVLOVER
Thanks! I have two speaker boxes behind the front seats. I mounted some brackets behind the dash and put two 6x9 speakers there. One behind the glove box and one to the left of the steering wheel. Tight fit but I got them in. The speakers and radio were free so I just had them laying around. Eventually I'll get a nice sub and maybe a backup cam since the radio supports it. It took about 3 hours or so to make all the cuts, a little more to run wires to try to keep them hidden. That plastic melts fast! The metal wasn't so easy, ruined a saw blade making the hole big enough. I cut two lines on either end and bent the original dash pieces back. Not the best hack job, I shouldve taken time to sand the edges, but its covered by the plastic so not really noticeable.
I bought a hidden antenna with a booster and installed it behind the dash too. Wired it to the acc wire for the radio for power and it picks up stations great. I was a little skeptical about it but I got it free too thanks to Bing and Amazon!
Awesome.
For the sub if you're not looking for a super expensive competition set up get a Car Dual sub kit. They have on that's a 10 inch sub 300 Watts output. The amp is made inside the box. The only wiring you do for it is the ground, power, and outputs from the radio. The controls and runners are on the back of the box. It's a basically self contained sub. You can get them at Walmart I have one and love it.
howardc
KY
Awesome.
Thanks I'll have to check it out. Just got my accessory charger in the mail today so I'll have to wire that where the cig lighter would've gone.
CUCVLOVER
Well my truck has sat for almost a week without being started. Yesterday I got in and it started before the engine crankded over twice. It really makes all the blood sweet and sour words worth it when the truck runs like that. Then I took off to dover. Held that truck at 50-70 the entire way there and back with out a single hiccup. That truck sure does eat up the road at that speed and yes it's screaming but I like a screamer. Also if a cucv hi brighted you last night in Dover I'm sorry about that I didn't notice they were on High.
Recovry4x4
LLM/Member 785
1,808
GA Mountains
I was jonesing for cruise control this week. Wouldn't have been worth much in the mountains but I had 450 miles each way that I would have really enjoyed cruise.
ODFever
Madness Takes Its Toll...
73
Orlando, FL
Please see my post #3377 in this thread. A short metal broom handle works well as well. I alternate between the broom handle and the bat. the bat needs a little bit of tape on it so it stays on the pedal. Without the tape, the bat slides off. The broom handle needs one minor modification. I put a rag over the end of it to provide some cushion for my hand.
3jumpjeep
Linsdale, TN
My everything hurt by the time I arrived last night. She was built for neither comfort, nor speed.
Sent from my SCH-I545 using Tapatalk
3jumpjeep
Linsdale, TN
I should have thought of that. And I have a Tee Ball bat I the truck. It's good for many things. This will make the ride back next month easier.
Another Ahab
4,556
Alexandria, VA
950 miles/25 hours in the right lane.
Has anyone thought of installing cruise control?
Two drivers?
No, just me and my dog Ginny. I used to let her drive, but only I my Jeep. Lol
There was a brief period of about 5 years in my lifespan when I could do that sort of thing.
And that moment has long since come-and-gone. :beer:
RobM36A2
9
The Netherlands
A cruise control would be nice indeed.
I don't think the LEO's overhere wille be amused by a redneck solution for cruise control, so please a proper push-the-button-to-engage one :recovry4x4:
3jumpjeep
Linsdale, TN
You are correct about the LEOs. Most wouldn't understand backwoods logic.
More frequent stops or a co-driver is to be recommended.
Recovry4x4
LLM/Member 785
1,808
GA Mountains
Speaking of average speeds, this was from my return trip yesterday. My moving average was 65.1 but ran into a road closure in my neighborhood and had to make a U-turn. I didn't stray from the truck at all the entire trip.
rsh4364
15
greensprings ,ohio
Oil and filter again.I used rotella T5 this time since it's finally warming up outside. Used 2 quart filter STP# S373,I change it every 3000 miles, since I am driving 600 miles per week it's about every 5 weeks.Also picked up enough 1-0 gauge copper cable to finish my battery cables and I got a good deal on a 24v direct drive new GM starter. Sadly when I have time to work on my 1009s I have no $,and when I have $ I have no time!
