2deuce
- 154
- 63
- portland, oregon
This truck was driven in to it's parking spot and not turned over in about 9 years. The fuel tank was drained, new fuel filters installed, and 4 lines bled at the injectors. The remaining 2 lines are stuck and will twist off before I can get them loose. PB blaster has been used for days without any success. The engine turns over fine, but no smoke exits the exhaust. I pulled one injector bled it, but it would not pop off while cranking the engine with it outside the head. The injector I pulled was very clean on the outside including the tip. I'm thinking that I have not bled them enough, but I saw fuel pumping from the inlet connections while they were tightened. Since fuel squirts out the lines at the injectors, I'm thinking the IP is working. There is no fuel moving in the clear injector return lines. The only thing I can think of is bleeding the lines more, but how much is enough after fuel is seen pulsing out? Suggestions are appreciated.
Many Thanks
Many Thanks
