kfrosty
- 7
- 0
- Belmont, NC
My 2 man, I had a starter go bad. Or that's what I think. One day it just wouldn't start and with power getting to the hot switch on the solenoid. Replaced with new starter and things worked fine.
I replaced glow plugs, installed a S3 controller, matching TSU, installed the octopus grounding harness.
The other night, I was going around the property when all of a sudden the headlights started flickering. Then shortly after, there was smoke. I had a flashlight and it came from under the drivers side dash.
I had outside lights, dash lights and heater fan running. Fearing a fire, I shut everything electrical off and the engine. Opened the hood and didn't see anything. So I started it back up and only turned on the headlights. Road around for another 30 minutes.
No issues.
Yesterday, I went out and took the instrument panel out and started looking for a scorched wire. I've looked under the hood and have found nothing.
So I went to start it and the wait light wouldn't come on. Just flash one time and it was a little hard to start as it was 40 degrees.
When it started I noticed the volt meter indicated the alt wasn't charging either. The alternator I suspect had bad diodes as I can see a draw on the batteries with everything off and only when the charge wire from the starter to the alt is connected.
The guy who sold me the alt got me another one. I installed it today. Wait light comes back on now, volt meter after running a 30 seconds or so is showing a charge again.
The thing that worries me is the smoke came from the dash I think as nothing came out when I opened up the hood the night of the problem.
Everything appears to be working now but it worries me that I may have not figured out what the problem actually is. WIth the new alt on, I turned on outside and interior lights, turned on the heater and no issues.
Again I can find no wires with soot on them or see any arc on any metal and the smoke was so bad I would have thought there had to be something.
Thus, curious as to if anybody else has had an issue like this and if you ever figured it out.
Thanks
No issues.
Thanks
