74M35A2
- 317
- 83
- Livonia, MI
So the inlet area of the 5" Donaldson Air Ram scoop actually has less area than the ugly military mushroom cap. The Donaldson measures 5.5" x 6.5", and the mushroom measures 9" diameter with a 5" pipe up through it. Inlet velocity is probably pretty slow across both regardless, and in my opinion the Donald Duck looks way cooler, but if you are buying it to increase inlet area, it is a step backwards. I doubt the "ram air" effect is enough to make up the difference, as these trucks top out at 67mph or less. Just FYI.
