Suggestions on hard top rear window seal.
Jeeper10
Freeville NY
I purchased a basket case hardtop with the older style oval one piece rear window. I want to remove it before blasting it, grinding it, welding it ect. The seal is going to fall apart in doing so. Any suggestions on a replacement seal?
Thanks all.
73m819
326
gainesville, ga.
Any body or auto/truck glass shop WILL have NEW rubber window seal.
rustystud
3,074
Woodinville, Washington
That seal is harder then you think to get new. I finally got one from LMC truck parts. It still is not correct and now I need a larger piece of glass since the seal is smaller then the stock one. The good news is that is just a piece of flat glass. The bad news is finding the correct measurements of the glass.
rosco
30
Delta Junction, Alaska
The seal is generic. When mounting glass, I learned to use tire grease to lube the seal first. About any glass man can make a pattern for you.
rustystud
3,074
Actually there are about a bazillion different style and types of rear window seals out there ! I went to every body shop, NAPA store and window replacement company between Woodinville and Bellevue ! No one could match the original. Some where pretty close but no dice ! So I finally got a rear window seal from LMC truck parts for a 1954 GMC truck. I use silicone myself to install window seals. I didn't want to pay the cost of having a window shop make up a new glass for me, but that ship has sailed !
Jeeper10
Freeville NY
Thank you everyone. Found a suitable replacement (I hope) at s local custom glass shop. It isn't exact but appears it will function and look fine. I'm a long ways from needing it but wanted to be sure I could come up with something before removing the old one. Cheers
Cape Coastie
CWO4 ENG/MSS, USCG, RET.
528
124
Sandwich, MA
Something like this would look pretty cool and probably work out well. Not sure if you need to stick to stock look. It is a boat window and they come in all kinds of sizes. Just a thought. Thought about doing this to my 5 ton hard top but the window is is good shape.
Cape Coastie
528
124
Sandwich, MA
Pretty much any boat supply stores will have a list or catalog with manufactures of these windows, West Marine is one. Just google boat windows and I am sure many choices will come up. Hope this will help someone.
