NP205 T-Case found!
Recovry4x4
LLM/Member 785
1,822
GA Mountains
Now that is a rare beast. A SM465 with a 32 spline output shaft. Most all 4X4's that used the SM465 had a 10 spline output shaft that went into the NP205 transfer-case.
Yeah, the 32 spline jokers were 81 and later. If it had a 205 behind it then 85 and later. I have the 10 spline stuff as well but since it will cost the same monies to replace my worn main shaft as it would to use the good 32 spline gearbox, I'll go 32 and eliminate that drive coupler.
