Dualled m101?
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
I've been toying with the idea of making a flat bed(truly flat, not m116 flat) m101. The frame I'd use is one with the old m37 style wheels. I'm thinking of running at as a dually, anyone ever done this? It should work with the m37 rims, right?
Recovry4x4
LLM/Member 785
1,808
GA Mountains
You will likely need a spacer between the rims. The M37 rims will be just shy on backspacing. Considering the same on my trailer salad 116 only 8 lug. Need a lathe to turn down hubs.
goldneagle
1,014
Slidell, LA
I have some nice tires already mounted on 16" rims that are made for dually application. Power King 8.00R16 tires. I got a total of 9. 5 are new and 4 are 90%.
gimpyrobb
27,786
755
Cincy Ohio
Between the rims or the hub? I was thinking rim, thimble, rim, lug nut.
I wasn't sure if the 1st rim would hit the trailer frame.
Recovry4x4
LLM/Member 785
1,808
GA Mountains
Not sure on frame clearance but the spacer will be needed between the rim. There might be a rim somewhere with right offset.
Ferroequinologist
Resident railroad expert
742
Liberty Hill, SC
The rims used by the wagon type trailer (walkerhunter's command camper wagon he got from Papabear) has the correct dually rims with the old m37/m101 bolt pattern.
I always wanted to find 4 and make a dually m37...
Recovry4x4
LLM/Member 785
1,808
GA Mountains
Perhaps we can bribe him into going to Findlay? He will never notice that all.his wheels were swapped out for M37 stuff. I'm surprised that Roger doesn't have 3 or 75 of them laying around.
