Shift Boots
ARYankee
33
Benton, AR
I've been looking for some canvas shift boots for my transmission and transfer case. I've found some here and there but usually not what I'm wanting to pay. I came up with the idea of making my own since I have some fabric left over from redoing my seats. That way they will match. Is there any tech drawings or manuals of them out there or can anyone that has them take some measurements? Does anyone have an NSN for them? I was also looking for input on how to do the ring that will bolt to the floor as well. Any input is much appreciated.
Srjeeper
40
NE, Pa.
The Best......
The best you can buy come from Jatonka....his are made from orginal paterns with the correct canvas material.. www.jatonkam35s.com
There's several of us on here that have them and I've never heard any complaints.......[thumbzup]
ARYankee
33
Benton, AR
you can find them on ebay ever now and again, good luck with finding a set. everyone wants them and not too many people have them.
Yeah. That is why I was hoping to find the pattern so I could make my own. I have some digicam fabric that I used on my seats so I figured I would do the boots to match.
jwaller
19
Columbia, SC
jtanka sells them cheaper than you can make them. his don't have the rings but if it means that much to you then you can add them yourself.
Recovry4x4
LLM/Member 785
1,808
GA Mountains
The set I got from John had the rings. FWIW my first set I got off ebay. I had to open the wallet 75 clams wide to get them. JTTs are much cheaper. Install is a breeze with a cordless driver and some TEK screws.
Srjeeper
40
NE, Pa.
My TC Lever boot and Trans.Shifter boot from JT both had the metal bands/rings with them.
If ya want to make your own than all ya need is to find the paterns. These came as part of the Artic Kits orginally, so maybe you can find something by looking in that direction.
ARYankee
33
Benton, AR
Cool I didn't know that they were part of the arctic kit. That may help. Thanks for the input folks. Keep it coming.
1,132
A.
For the price, I don't think you can do better than Jatonka's boots. Sure, if you have some camvas laying around you can make them, but what's your time worth?
B.
Both sets I've bought had the rings, although I thought the rings weren't the best fit (but I've never had a truck that had an original set, so who knows if these are better, worse or the same).
C.
Georgia doesn't have a lot of artic weather but these sure do help with the rush of hot air coming up through the floor in the summer! Especially since I have dual spring ride seats-it's a pure vertical rush of hot air coming up through the transfer case hole in the floor when you're driving.
rustystud
2,987
Woodinville, Washington
C.
Georgia doesn't have a lot of artic weather but these sure do help with the rush of hot air coming up through the floor in the summer! Especially since I have dual spring ride seats-it's a pure vertical rush of hot air coming up through the transfer case hole in the floor when you're driving.[/QUOT
That's why I like the Summit ones. They totally seal the shifter shafts. There is no air getting in from there !
