kb3bf
- 2
- 16
- Howard County Md.
The original pads are the pink ones, notice the small tears at the corners probably due to the FET screws being too tight. Not wanting to risk a dielectric breakdown, I replaced them with the gray ones. Thermal compound was added to offer better thermal dissipation for the FETS.
The fuse holder was mounted on the regulator's bottom side, facing downwards. This was not the best choice, but the only possible one. The top side is blocked by two transformers and a pair of caps, the sides are blocked by the FETs and heat sink. I had to find the smallest 250 V type fuse holder to make it fit. A few dry runs determined where to mount it on the bottom surface.
So the goal to check the regulator out also resulted in addressing the critical fuse mod.
