Any aftermarket seat options?
DukeNukem
AZ
Looks like I joined in 2007.
Two weeks before the housing bust hit and all my homes went down in price 80 percent.
Reason for not being able to buy any steel.
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
Type this number into the search box on egay.
151475603921
You can find them cheaper if you look around.
Recovry4x4
LLM/Member 785
1,808
GA Mountains
Hey, that is the bolsterless version of the seats Auctionaddict has. I have a PR saved for a rainy day.
EnteJager
NJ
MaterCraft seats I installed on my M988. The rear seats bolted to 3/4" spacers directly to the rear seat boards were made out of round bar aluminum stock. I couldn't have designed them any better, they flip up and you can still access the storage underneath.
The driver seat has been changed to the same as the front passenger seat, older picture.
I opted to use the 3 point installed safety belts, the 4 points that came with the seats where attached to the seats, I didn't want to assume the seats would remain secure in a crash.
cruzinz28
Maryland
I want to explore seat upgrades myself. Here are the seats I plan to install. The taller one will be used as the Driver and Passenger and the Shorter Fold-Up Seat will be used for the rear seats. I also have 5-Point harnesses that came on the taller driver seat that i will try to utilize as well. For the Driver seat I scored the upgraded seat base so i have something to bolt it to as well.
Great Picture EnteJager! I am going to save them as reference when I got to install mine.
TNriverjet
24
Clifton, TN
One member here (3000gt, I believe) found a set of four bucket seats at a junk yard for $100. I really like the seats pictured above, but for the price I may be hitting the junk yard when I need a set!
