Another Ahab
4,317
Alexandria, VA
Alright well over the weekend I drove Gunny to Fayetteville,Ga. I figured out another issue on the way back. Gunny needs a transmission I lost 3rd gear in Whitesburgh,Ga. He still made it all the way back to Alabama pulling a trailer and motorcycle. When you lose 3rd in a 3 speed trans your top speed becomes 30 to 40mph though. Probably going back with a 700r I wonder what kind of mileage I will be getting with a 700r and the 3.08 gears.
Did it just drop out while you were underway; one second pulling and then next second only rolling?
Recovry4x4
LLM/Member 785
1,806
GA Mountains
You may not see tons of improvement in mileage with the 700R4. The 6.2 will be straining to maintain speed geared down with OD. In town mileage will likely increase with the 3.06 first gear. It's certainly a worthy swap.
cucvrus
10,056
Jonestown Pennsylvania
Are you sure it is not the kick down switch on the throttle pedal or the shift modulator on the side of the injection pump?
GunnyM1009
529
Roanoke/Alabama
Im pretty sure the shift between 2nd and 3rd had been feeling very spongy for a while plus there was the big white cloud of burnt trans fluid that was behind me before I realized it went and just started shifting between 1st and 2nd but I dont fix things until they break. I was expecting it to happen soon I was just checking out what I wanted to go back with last week and was planning on picking one up soon it just happened a little sooner than I wanted it to.
junkpart
lagrangeville ny
put new 180 thermostat with weep hole and fleet charge antifreeze. soon to put a fluid filled harmonic balancer. have any reviews on which balancer is good?
junkpart
lagrangeville ny
I have a 700r in my k5 with 3.73 gears its my everyday driver great mileage close to 30 mpg. Has fine power wile regular driving. towing I don't use od and only light loads
Mainsail
1,539
Puget Sound, WA
I parked mine in the driveway, chained the steering wheel with the padlock, and flew to Hawaii for the week.
We have a beach cabin at Bellows AFS for the week. This is the view from the back door this morning.
CUCVLOVER
Yesterday I went and did a little wheeling while I was close to a creek. On the highway I held that diesel at 3k (70mph) for very long stretches and I had no problems. It's a long ride from my house to dover in the cucv lol. Pipes popping, engine roaring, stereo rocking. But I had fun running it. The truck did great in the rocks and water I had. Water up to the bottom of the door a Couple times so I did wash the bottom of the truck lol
Sent from my XT1585 using Tapatalk
MountieM1010
Edmonton, Alberta
This week I just finished installing a 4 gauge dashpod and a new set of Goodyear Duratracs size 285-75R-16. As I now have 4.11 gears I decided to go that size. Hitting around 3000 rpm at about 60mph.
Another Ahab
4,317
Alexandria, VA
The truck looks great CUCVLOVER.
I am amazed that that creek there is running clear; beautiful!
I'm guessing that there are no subdivisions out that way. Is it all mostly rural with good cover crops?
Or am I totally wrong?
CUCVLOVER
Thank you
I am amazed that that creek there is running clear; beautiful! I'm guessing that there are no subdivisions out that way. Is it all mostly rural with good cover crops?
Or ami I totally wrong?
That is leatherwood Creek. I was on East fork leatherwood road. That is all hills and hollers, deliverance type area. Just little houses here and there with lots of rock in the ground and bedrock Clift's.
