Things I would consider...
Howdy,
A few things you might want to consider when buying a simple step down converter are:
1 - The device should implement PWM technology
https://en.wikipedia.org/wiki/Pulse-width_modulation)
2 - No load current draw: You don't want the converter to draw power if your are not using it. Otherwise you could literally kill your batteries while the truck is parked even is there was no 12 volt load on the system!
3 - Multiple electrical protections: The device needs to be capable of detecting and protecting itself and connected devices from at least: short circuits, over-load, high and low voltage fluctuations.
4 - 13.8 volt output: If you are going to charge 12 volt batteries or devices you will need an actual output of closer to 13.8 volts! Low voltage would also reduce the power of two-way radios and could reduce the functionality of other devices.
5 - Duty Cycle: For our use the device needs to be rated at the lower voltage as a "continuous service" and this will require a design that addresses cooling. A large unit may use built in fan(s) and require mounting in a well ventilated area.
6 - Be aware that "surge" or "start" voltage/amp ratings are usually for a time period of a few seconds at MAX! Always look at the "Duty cycle" rating (amps and time)!
7 - Fans are noisy, where are you going to mount the device?
8 - In our case the device should also be designed for rugged use.
I am building a camper in the bed of my 923A2 and I would rather have two smaller units (one in the cab and one in the camper) than one large unit with all of my eggs in one basket. Personally I am staying below 60% of the rated "Duty Cycle Load" for my units (if I have 30 amps of load worst case then I will use a 50 amp duty cycle rated device).
ALWAYS install a fuse or circuit breaker between your power source and the device!
As in most cases with electrical equipment you get what you pay for...
YMMV...
Happy Tails,
tom n tyler!
