Ilgy85
- 0
- 0
- Denver of the East
I've been looking around for a while, gathering knowledge and decided to swap an nv4500 into my 1984 m1008. I used a hydraulic pedal assembly from a 1986 and a nv4500 from a 1994 6.5 turbo truck with a solid mass flywheel and sprung hub clutch kit for the same truck. Everything went pretty smooth and I love the overdrive. I have 4" tuff country springs in the front and an ORD shackle flip in the rear. I ended up with 8 degree shims in the back to fix the pinion angle. My main and most aggravating problem is I have a vibration at highway speeds, 60mph+. The vibration sounds more like gear chatter than anything. It only happens in 5th gear when there is almost no load on the system. Accelerating or let off completely and the vibration goes away. The vibration is non-existent in 4th. I had a shop balance and straighten the driveshaft and install new spicer u-joints. I had the transmission rebuilt. I had the rear end rebuilt. I installed a new balancer and motor and trans mounts. I still have the same problem and it has not changed despite all the work. Does anyone have any ideas that I haven't done yet?
