Mike82ndABN
- 10
- 0
- Tampa/Florida
Pinhole leak in the sidewall, likely from a thorn. Looks like I am going to be buying a new tire. I don't want to kill myself so I thought I would ask for help. I have read that I need to remove the valve core to make sure I have ambient air pressure, remove the 12 bolts, separate the two parts of the wheel, remove the tire, get the runflat insert out (this should be fun), put the insert into the new tire (more fun), then put it all together again.
The putting it back together process is what I need help with, do i use grease packs in there (i read that they are in there to reduce friction if you drive on the runflat), do I have to replace the o-ring and which one (red or black). And I read about 3 washers that get used as spacers on the bolts, and what about something to seal the bead? Torque values and double torque sequence seems straight forward. And what about balancing?
Once it is all together am I risking my life if I don't have a cage to air it up.
I'm in Tampa if anyone knows a good shop out here.
