Corvette1974
- 1
- 18
- Upper Black Eddy, PA
Hello. Long story short, my deuce has been having drivetrain issues. First it started with finding metal in the rear axle (still haven't messed with this yet)
Second, the driveshaft vaporized as I was going down the highway. Took the parking brake with it. Put a new unit in and it works fine, but now I am having two issues. How critical is it to get the U joint to purge when greasing? I cannot get it to at all. Pumped like a whole tube through each fitting with driving in between. I even pulled the two u joint cap bolts and it didn't make any difference. Any tips without destroying my driveshaft/ujoints?
The major problem is that the front most rear axle seems to have a lot of play in the input yoke. Drivetrain makes no sounds while driving. But I was thinking that maybe this caused the original driveshaft explosion. It has play in the side to side motion about a 16th of an inch at least. More than the other axles. No major leaking. It does make a nice metal thudding sound when moving it around by hand. Is this acceptable or do I have issues?
Will
Will
