chiefgguy
- 1
- 3
- Magnolia, TX
I have a MEP-003 and in the past couple of weeks have had a problem with the fuel pump. When in the Prime/Run position there is no "noise" from the fuel pumps.. In the Aux Prime/RUn it makes all kind of "noise".
Removed the first fuel pump, and pull the screen and careful to keep track of the magnet , and then put it back together and for "sh*ts & giggles" tried the prime/run position and it made noise. Then it stopped..
Not sure exactly where to go from here , i used the wrench and tapped on the MEP frame (not pump) and it started to make "noise"! While this was sufficient to get us up and running, I'd like to try and figure out how to fix it! After about an hour or so, the unit struggled with getting fuel, so we added some and it continued. Gently tapping the frame while running seemed to resolve the issue until we shutdown for the day..
My assumption is maybe there's some crud in there that needs to be further cleaned out or possible in pump #2. I did no take pump #2 apart.. THis unit has been pretty flawless for our off-grid cabin for the past 4 years, and we do run Diesel Kleen through it and the fuel doesn't sit very long before being used. (almost 1-2 starts every 2 weeks the unit is run quite regularly)
Additionally I have a question around the electric supply to these pumps, how does that wire come off there? It appears they are crimped, and if this is covered in a Field Service Manual I'm happy to go look it up. In the manual I currently have I didn't see it covered there. (I know there's a couple different manuals in the compilation set)
Thanks in advance for your advice/help.. This is has been a very helpful site for us to get to better understand our MEP over the past several years!
Andy
Andy
