C/K Radiator.. is there a difference???
richingalveston
120
galveston/Texas
c trucks are 90's models I believe
spectra cu850 is perfect change find copper and brass version
the link you posted took me to an empty shopping cart could not see radiator
royalflush55
529
Reydon, OK
C30 is a 2 wheel drive 1 ton, while a K30 is a 4 wheel drive 1 ton. Radiators should be the same. Look for a four core(4 rows of tubes running horizontal) radiator for increased cooling.
cucvrus
10,316
Jonestown Pennsylvania
Most of the replacement radiators have 3 rows in the core. That works. i have one in my Crown of Thorns logging M1009 and pull trailers loaded all the time with everything all stock under the hood. 124 K and still holds its own. i get it to 210 at times on hard pulls but she goes down quickly when I peak the hill. I tried an electric CVPI fan on the front of the radiator. it made little of no difference and I just removed it.
Drock
12
Eatonton GA
Well got my new all aluminum radiator installed Saturday and it definitely made a big difference. Temp doesn't go above 200° even with the EGT at 900°. I also replaced the fan clutch and the harmonic balancer. I'm glad I did, the balancer didn't look like it was wobbling, but it sure as heck runs much smoother with the new one!
Drock
12
Eatonton GA
Thanks for the updates, can you also post part numbers of the parts you had success with?
Here they are....Harmonic balancer (Dorman) #594-128..... Cooling fan clutch (AC Delco) #15-4911..... Radiator (Genesis auto parts) #ALL34728X2098AA.... I was unable to find a harmonic balancer installer with the correct thread & size. Soo I bought/ordered a bolt & nut 3X longer then the balancer bolt to use as an installer. Also you should go ahead and order some radiator support bushings. Oh and make sure to use thread lock on all 8 fan clutch bolts, mine started to back out.
cucvrus
10,316
My mistake. I did buy them from energy suspension. I will do better in the future. I am sure that I can correct myself. That was a quick Google mistake on my part. I am WRONG. I will do my homework and sharpen my pencil. If you know the correct Energy Suspension part # share it. Please.
cucvrus
10,316
prothane is a brand name that is on the Energy Suspension parts .com website. They are a vendor. The radiator support parts for Energy Suspension are not sold separately They are part of a complete body kit only.Something about them not being compatible with the cab mounts. Total BS. But I have used the Prothane ones in the past thinking they were Energy Suspension. There you have it. It mattered so little I never noticed. It held the radiator in place just like wooden mounts I seen guys fab in the past. Sorry for the misinformation. Tomato Tomatoe same thing.
86m1028
17
Murphy TEXAS
I wasn't bashing you, just making it clear those are 2 totally different company's.
This might sound extreme but think of "snap on" & "stack on" tool boxs.
One is a lot cheaper than the other & there is a reason why, apples to oranges.
Again, not an attack on you, just trying to be clear about name brands.
I ran into this when I was looking to order energy supension parts & got redirected to that site. Yes prices were cheaper but it wasn't name brand parts.
Kinda like "bait & switch" too me. Luckily I caught the switch before it shipped & canceled the order.
tommyd
1985 M1009 Rad
Hello All,
My rad just **** the bed this am. I checked out the one you called out. LT warranty, AL and pretty cheap. Is that a direct replacement for a stock M1009? All I really care about is all the correct ports. Hopefully, I can get all the additional fittings/lines out of it, without replacing them too. In addition, anything else I should do when I break it down and replace?
Thanks,
Tommy D
PJL
Way south of Seattle, WA
I used the Chinese made aluminum plastic tank radiator from CARQUEST. Fit was perfect. I used CARQUEST only because my employer has an account there. I changed out the belts while it was out. Also be a very good time to change all your hoses.
Drock
12
Eatonton GA
Hello All,
Thanks,
Tommy D
Yes it's a direct bolt in. All fittings bolted right in. I liked this one because there's no plastic tanks.
usabamaman
23
Anywhere, Alabama
Hello All,
Thanks,
Tommy D
My original radiator starting leaking in the body shop just sitting there. I bought one that is exactly like OEM, but it was about $450.00. I got it from a local body shop supplier.
