m715mike
- 3,822
- Montgomery, Texas
Looks like you only moved half of the M931....
The lady that I got the scale ticket asked me "Whats wrong with your front axle?"![]()
That its so much heavier of a front axle weight than most/all of the commercial vehicles normally over the scale.I admit, I'm a little slow. What is she referring to?
Matt did she understand the truck is rated for I believe 106,000 pounds? ...
Right - Its just very heavy for an unloaded truck. Its heavy for a loaded truck, too. They usually aim for 12k - 34k - 34k.They are just used to the common amount of probably 6500 or so on a regular semi. Atleast she knew what she was looking at and noticed a difference...
The only fuses on my truck are between the batteries and the batter equalizer and then what is related to the transmission ECM.Back in page eight picture of battery set up. Is the smaller power wire marked in red fused? That wire on my 920 always bothered me that there was no fuse close to the battery connected point incase of chafing. Truck and trailer looks great.
