LED's and Lumens, colors, best human visual spectrum .... and all the jazzzz
coachgeo
3,480
North of Cincy OH
did a rather large search to see what was on the board already and didn't see much that got into the details of where LED may NOT be the best way to go beside power saving. Am no expert on the subject so just going to pass on below info that might enlighten some folk to when LED may not be best way to go for some types of lighting.
Anyone got specs on the Military LED's color ranges (K), lumens etc. of the lights used to illuminate a dark path? (head lights/Aux night lighting etc) Now the parking/convoy and brake lights etc. that is different but would still be interesting to know specs. Assume their main advantage is longevity but some must be- better view of each other's vehicles (particularly behind) us.
http://www.expeditionportal.com/for...ng-for-the-Off-road-Adventure-and-Camping-Rig
http://www.ledsmagazine.com/article...pplications-require-unique-sae-standards.html
Kelvin-Scale-and-Color-Temperatures-of-Common-Lighting-Sources-Paint-Correction-Christoher-Brown.jpg
gimpyrobb
dumpsterlandingfromorbit!
27,786
770
Cincy Ohio
When I went from incandescent to led, the difference was impressive! I attribute that to the color of the leds.
I have no numbers to post on them though, sorry.
gimpyrobb
27,786
770
Cincy Ohio
Ahh, sorry. 1975 m35, trucklite head lights. I have the grote rear leds and trucklite front turn signals, but was mainly talking about the head lights.
Recovry4x4
LLM/Member 785
1,822
GA Mountains
A point once brought up was heat generation. Do they generate enough heat to keep from icing up in the winter?
gimpyrobb
27,786
770
Cincy Ohio
They do produce heat, but I try not to drive in the winter to keep salt off the truck. I doubt they would have issues keeping accumulation off.
Shark Bait
59
Charleston, West Virginia
I have the newer TruckLite's in my HET and I had the option of a heated or non heated version. I got the non-heated version because I don't drive it much. They are way brighter than the original headlights and a little brighter than the older TruckLites in my LMTV.image.jpg
Pointman0853
14
Gardnerville, NV
I went with Hella direct replacement housings with 55W Halogen bulbs. Plenty bright enough for 56 mph, however.. :not worthy:
If anyone is interested, check out Cyclops Adventure Sport. (http://www.cyclopsadventuresports.com/). They produce LED replacement bulbs. I have used with great success on my KTM Rallye motorcycle with dual projector beams. They are plug and play and run around $60.00. Pretty much the ultimate fix when you need extreme output.
Pointman
Shark Bait
59
Pointman
I have a KTM 990ADV and ordered the European headlight. It is 50/100 watt versus 50/55 watt American (I believe are the correct values) much better than stock.
Dave
papakb
1,194
San Jose, Ca
I've replaced almost every tail light bulb with 10-30 volt LEDs so that everything is interchangable and the trailers can be pulled by military and civy trucks without having to do anything to the lamps other than make up a pigtail so everything plugs into everything else. The one issue I have is finding an LED that isn't too bright for the running lights. As of right now all I've been able to do is paint black over the lamp to dim it down a little.
BTW coachgeo, lighting circuits are the same throughout the M series trucks so none of this is vehicle specific. The numbering follows a fixed set of specs and those can be found here:
http://olive-drab.com/od_mseries_circuits.php
Kurt
KG6KMJ
