The wire tie, that holds the fuel line to the injector pump is there as an TACOM approved "field fix". The fuel system on this gen set is the only problem I have with the 2 KW. It always, I mean always, has air in the lines. So to "correct" this fault, after hundreds of hours of study and experimentation, the fix is............................ a wire tie to hold the fuel line down below the fuel/water separator bowl. Your tax dollars at work. So maybe you need to pull the new hose down, or maybe shorten it a bit.
