What kind of wheel is this?
Buffalobwana
178
Frisco Texas
Is it a HET wheel? I can't find any good images of HET wheels on Google, or maybe my Goo skills are weak.
juanprado
2,953
Metairie/La (N'awlins)
tire size is correct for a het.
I picked up one het wheel that went to castlebravo. PM him as he can verify.
I don't think it is a het but an mrap. The het wheel had 2 valve stems that then had metal tubing to a valve for fill and ctis. I just don't see a corresponding hole on the other side.
simp5782
Feo, Fuerte y Formal
9,405
Mason, TN
It is an MRAP wheel. They even come in those variations in aluminum. About 65$ Ea for steel and $150 for aluminum. On fleabay.
Sent from my SM-G860P using Tapatalk
Buffalobwana
178
Frisco Texas
The lugs look like they are quite far from the edge. Doesn't look like MRAP I see online. Looks like the bolt pattern is small.
gringeltaube
Staff Member
2,558
Montevideo/Uruguay
You are correct about that; what you have there is an aluminum wheel with a std 10-on-11.25" bolt pattern and 8.66" pilot hole. Most MRAP wheels have the larger 335mm bolt circle, with the 281mm pilot hole.
I just found out that the early model (A1) Buffalo MPCV had these wheels on the front axle, only. Tires were the same, of course.
One of the later model A2's improvements was just that: they came with identical wheels front and rear and could use the same spare, all around.
Below is a picture of the A1, from the internet...
G.
tobyS
833
IN
MRAP I think. And the one shown appears to be steel, which is 1/2" thick at the bolt. Probably Henderson.
I bought 12 of them at GL, made by Henderson and have the 20 bolt ring. They are hub piloted and will fit most semi axles, which have the same BC. I've devised a lug nut to use them on the stud pilot 5 ton.
Here is a picture of the rim and here is a combination that I made using the offset outer (20 bolt) of a rim that came on the 450/80/R20 Sand Trail tires (with 13.19" BC). That makes a 12" wide rim from the combination that will fit a semi axle or 5 ton with 10.25" BC.
