Operation "URGENT RESTORATION"
m38inmaine
95
Maine USA
Installed the solid state directional system today, the original mechanical unit was a little crunched, all lights work and are nice and bright, nice to see the dash all lit up.
quarkz
Supreme Galactic Cleric
71
Kennewick, WA
Is the dash lit with the standard configuration , or did you supplement with LEDs? That is a dash, that even I could see well enough to drive by.
Sent from my Galaxy Nexus using Tapatalk
m38inmaine
95
Maine USA
It's the camera that makes it look very bright, they are bright by half of what you see, standard bulbs.
On another note I found what was wrong with my engine. The clip that I repaired on the clutch fork ball stud broke and allowed the fork arm to hit against the pressure plate bolt heads, that was the noise on starting. Working now to separate the engine just enough to get over the ball stud to get the arm out and install a new clip. I wish I would have waited and installed a new one, lesson learned a $2.50 part costing a half day of aggravation.
kubotaman
135
RI/MI
This might sound like a stupid question, but what happened to the other carrier? I might of missed that post.
m38inmaine
95
Maine USA
The second carrier has a seized differential and a snapped axle shaft as a result I would say of the sudden stop. The articulation joint is wonky as well so I have been using it for parts such as brake drum and hub parts.
Got the goat back together pretty much where I started so no real gain today other than I hope to say it's fixed. Had to separate the bell housing about 1/2" to get the clutch fork over the ball stud and out of the housing. Picture is of the new clip installed, which only took a day to install.
m38inmaine
95
Maine USA
The center differential vent tube was crushed and bent so I grabbed some 1/4 steel tubing and bent one up. If you are a goat owner having these supplies on hand is a must. Attempted some aluminum welding today and decided it is best left up to the experts, did ok but I could tell it was hit or miss so I stopped before I made a mess.
m38inmaine
95
Maine USA
Bent up a new center differential vent tube, having 1/4 tubing and fittings on hand is a good idea for a goat owner. Attempted some aluminum welding today, it was hit or miss so I decided I better leave it up to the experts.
m38inmaine
95
Maine USA
Yes, the clutch release arm broke free and was hitting the pressure plate, a clip that holds it to the ball stud broke, you can see it in my thread above.
Another Ahab
4,691
Alexandria, VA
I never learned to weld aluminum, but I bet it's like most things:
- If you just did it often enough to keep your "hand" at it
It would probably look great. It's just hard to keep good at stuff you never practice too often, you know?
