Ilikemtb999
- 45
- 28
- Denver, CO
Just measured. Center of u joint to center of u joint is about 29.5" long on the stock shaft.
The dodge 208's have a fixed yoke. You might try searching.That's how long mine ended up being too. I am wondering if maybe my driveshaft is wider that other's? None the less, do you think if I got it lengthened it might correct my problems? I can't find an SYE for the np208 nearly as easily as the 205!
You can, just not with ORD parts.do yourself a favor and call ORD. get new front springs and shackle flip the back, no shims needed. IF all you want is 33's go with 2 iches but can't do shackle flip or future cross over unless you go 4
