WRECKER AIR VALVE 936a2
SLOrazorsedge
San Luis Obispo, Ca
I have that valve on my M936A1, however it does not lock the brakes? My truck also as the upgrade momentary push to release brake valve beneath the steering wheel under dash that I never understood what it was for as the brakes never locked. The auto idle up works fine while using the crane...so ya think a portion of my valve us inop?
rumplecat
221
North West Arkansas
My 936A2 has the hardware to go to the auto throttle but it has been disabled. I was unaware the system also locked the brakes?
Swamp Donkey
The Engineer
120
Gray, GA
From the -10 Manual actual Page #3-33
I haven't found anything on the valve under the steering column in the TMs since it was a modification kit. I did pull the information below from a listing. I'm not sure if it's accurate because I can't find it printed anywhere else.
Brake Lock Override Kit M936/M936A1 Wrecker
Brake Lock Override kit for military 5-ton wrecker M936/M936A1. Includes Valve assy. hoses, fittings, bracket, nuts, bolts washers, etc, installation and drawing instructions. This kit will engage the air brake system into a locked position while using the wrecker boom or for parking purposes.
M35A2-AZ
392
Tonopah, AZ
My button under the steer wheel does work and when you have the PTO engaged you can press that to release the brakes to use the rear winch to pull you're shelf out I guess.
Csm Davis
393
Hattiesburg, Mississippi
Okay here's the thing a lot of wrecker operators would disable the accelerator function so they could manually set the engine speed and I have seen this on 816, and 936, A1, A2, all versions. The brake release is for letting you move with the rear winch. A lot of the trucks are setup to and by the drivers to function as they want and need.
sent from my decrepit fingers
JARR Towing
Flagstaff, AZ
I have a 90 m936 a1. When I engage the Pto for the crane air is coming out of the end of the Pto control valve and also Out of the intake stack. Also when you hold breaks at a stop light I'm losing air out of the intake stacks. Could these be related? New to the military vehicles and any help would be great
86m1028
17
Murphy TEXAS
Well currently revs to limiter to compensate for the air leaking out of intake stack and power divider bleeder
I should have worded it differently.
When it's operating correctly what does it auto rev too ?
Im new to the military wreckers also.
I've been reading the tm's, had read about the auto lock brakes & brake override, understand them but didn't really see any info on the auto idle up (haven't dug very deep to see if mine has it or not, I do know if I DO have it, it ISNT working)
Did read the warning on the door about trans damage if left at idle & using the pto.
Im just trying to learn what options there are & the best way (for me) to operate mine.
The wrecker owners & guys that used them in service, have a lot of experience with them, know some good short cuts & still stay safe with them.
Doesnt matter how much you know, there is always something to be learned.
JARR Towing this isn't an attack on you.
Im betting you have learned a lot of little tricks of the trade with the civi wreckers !
JARR Towing
Flagstaff, AZ
I don't know when it's operating correctly what it revs to, bought the truck 3 weeks ago and totally new to it. I know civilian wreckers you don't want to idle past 1500 rpm Max
SLOrazorsedge
San Luis Obispo, Ca
I have a M936A1, the throttle kick up is part of the PT pump. When you engage the PTO for crane operations it auto advances the throttle to 1500-1600 RPM. Once engaged you pull the hand throttle all the way out and lock it.
M35A2-AZ
392
Tonopah, AZ
With your stop light air leaking, Sound like you have a service side brake diagram that is bad.
JARR Towing
Flagstaff, AZ
I'm replacing all of those today, but the Pto still throws me off. I know on my truck engaging the Pto locks the breaks up so that could be related, but the power divider valve is leaking out of the vent cap on it.
86m1028
17
Murphy TEXAS
The brakes locking when the pto is engaged is normal.
The brake release under the steering column is for self extracting with drag winch.
