1952 ReoM35 gasser electrical question
Tilyn52
Minneapolis
I just purchased a 52 M35, looks to be pretty nice shape. I ordered a tech manual, waiting for it to arrive. Wondering on battery hookup, is the entire truck 24 volt or just starting system? Lots of cables in battery box but no batteries. I'm new to the 6x6, work on trucks everyday but this is lots more interesting.
Kaiser67M715
26
NH
One cable to ground, a jumper between batteries, two off positive, one goes to starter the other to dash(or alternated/generator then dash, can't remember)
If there are two more, most likely those will go to a slave plug, used for jump starting
Tilyn52
Minneapolis
Thanks for the good info.There is the one going to ground and 6 other large cables routed into the box . Two go to what appear to be ford style relays/ solonoids on the firewall . Look to be fairly modern, not sure for what they were added.
Tilyn52
Minneapolis
Thanks. I have been looking at them, lots of good info. Still trying to get it to fire. No spark. Coil checks good. Filed the points to clean them up. Maybe it's a cranking speed issue. Seems s bit slow with the batteries I have.
Kaiser67M715
26
NH
Idle is only 450, mine cranks over at what sounds like 200 rpm.
Did you check for spark at the cap? Maybe wires are bad. There is the 8022 manual, I'll try and find the info and get it posted, gives you some step by steps to diagnose no spark. There are three or four condenser/capacitors in the distributor, so it is harder to diagnose a no spark
Tilyn52
Minneapolis
I will check the wires. That would be much appreciated. I'm trying to get familiar with the manuals on this site, trying to figure out where the info is. I seen those in the distributor but wasn't sure on how to test or there function. I did test the points condenser with an analog meter like I have for years and it seemed ok.
rustystud
2,815
Woodinville, Washington
The problem with testing a condenser with just an analog meter is you cannot test the charge. You need an actual condenser tester. The last time I priced one out they where over $300.00 . The best thing to do is just replace it with a known good one.
tobyS
835
IN
You might look into an electronic conversion. They seem to make them for about everything. I'm going to change my 73 F600 sometime to get rid of the points that always seem to need work.
ralbelt
9
West Warwick, R.I.
I was assigned a 52 reo when I was supply sgt back in the 70's. Ran great until I let another guy drive her to camp. He left the parking brake up an put the transfer case in low, went about 20 miles on major roads trying to keep up with the convoy till the engine blew. Take care of Her.
Barrman
1,734
Giddings, Texas
I never found a 8022 manual online. The pre 1964 TM for the m35 covers gasser and multifuels. I have used both to figure stuff out on my gasser.
Tilyn52
Minneapolis
Found out a big reason why she won't run, no compression. Finally got spark, points were grounded . Got fuel pump working. Would crank and kinda fire, try to run. So decided to do a compression check. 120 on 1, 0 on 2 and 3, 80 on 4, 120 on 5 and 0 on 6. Have not pulled rocker covers yet. Are rebuild parts available for this motor. Or look for a good takeout or convert to multifuel? Found a running multifuel for 750, have not researched on here yet how big a deal it is to changeover.
DDoyle
80
West Tennessee
Yes, parts are available for the gas engine. Not only from surplus dealers, but also commercial sources (aka NAPA) - the engine is a REO OA-331, which was also used in commercial applications.
As far as the gas to Multifuel conversion (and I know that there are several on hear that will disagree) - if you are planning on just riding around, the gas is the way to go. You can actually drive down the road and have a conversation, something you can't do in a Multifuel. On the other hand, the Multiifuel is easily started all the time, every time....and some folks like the noise.
Hope this helps!
David Doyle
www.DavidDoyleBooks.com
