- 3,227
- 3,277
- NORTH (Canada)
Last year my trusty LDT developed a knock, started to misfire/"pop" and became harder and harder to start. I decided to swap it out for a takeout LDS. Project creep led to a major refresh of the LDS before it went in and also the Waterloo 5th gear OD modification to the Spicer 3053A.
If you are rebuilding a LDS or LDT, or if you plan a LDS conversion, perhaps there is some useful info for you!
Here is a short video of the truck, startup and a shot of speed vs rpm. https://youtu.be/qUlbrEfXWIM
exhaust manifold nuts: http://www.steelsoldiers.com/showthread.php?142862-4-cylinder-lower-nut-exhaust-manifold-!!!!
preparing the LDS for the swap : http://www.steelsoldiers.com/showthread.php?142077-Preparing-to-get-an-LDS-ready-for-the-swap-questions&highlight=
clearance for pulling oil pan: http://www.steelsoldiers.com/showthread.php?144197-Clearance-required-to-pull-oil-pan&highlight=
cylinder head resurfacing: http://www.steelsoldiers.com/showthread.php?144087-LDS-cylinder-head-resurfacing-questions&highlight=
LDS vs LDT oil pump plumbing: http://www.steelsoldiers.com/showthread.php?145938-LDT-465-oil-pump-plumbing-question-switch-over-from-5ton-configuration&highlight=
ground hopping the LDS: http://www.steelsoldiers.com/showthread.php?155382-Ground-hopping-my-LDS-last-questions-starter&highlight=
she is alive! : http://www.steelsoldiers.com/showthread.php?155752-She-s-ALIVE-!-LDS-465-run-after-rebuild-refresh&highlight=
mating transmission to engine: http://www.steelsoldiers.com/showthread.php?155510-Mating-transmission-to-engine-rant&highlight=
head gasket oil leak on new rebuild: http://www.steelsoldiers.com/showthread.php?156284-New-head-gasket-advice-on-oil-leak&highlight=
Older Posts:
Sasquatch Santa's repower: http://www.steelsoldiers.com/showth...ring-The-Deuce-With-A-5-Ton-LDS-465-1A-Engine
Older Posts:
