Triple Jim
- 289
- 83
- North Carolina
Actually QRZ.ok how did you figure that out? ...........ah the power of google.....
73 de AA3DN
Don't be too sure about that. I don't understand any part of this discussion.I don't know... an Extra class amateur might not take too long to get it done.
I have replaced many over the years. Most had water problems. Several had water at least as high as yours. Contact erosion was also a problem, but not anywhere as bad as water. Internal wire harness failure, (mostly cold soldering) also happens, but seldom. The coil burning up was the second most probable failure.If anybody has their own experience with K1, I am interested in hearing from you before I remount it in the second MEP.
Hi Kurt,They all appear equally surface rusted. Might it just be due to humidity causing surface rust?
The heads of the screws look the same as the ones on the terminal strip in my 1997 802.
