scottmandu
- 35
- 28
- Texas
Post up an image of your condensor.
I have the idlersI am starting to collect parts for the a/c install in my 1078. Does anyone have a source for the bracket which supports the compressor bracket TV040127 as well as the idler pulley?
Based on the results others have posted, I may try to use a parallel flow condenser off a commercial truck.
Thanks
I've found a 21X21 or 22X22 parallel flow 5/8 thick condenser will fit in between the intercooler and the front air hookups.Great will send a PM regarding the parts.
Does anybody have the dimensions for the stock condenser?
After looking at my truck and the space available there isn't as much room as I expected to mount the commercial truck parallel flow condenser I was looking at.
May need to consult the A/C system engineers I work with on sizing the condenser.
Are you looking for an a.c. shop or a forum member to help put it together? I live in San Diego if you want some help. Putting a.c. in mine now.Good Evening.
I have a M1083 with a Cat C7. I have all of the parts except the bracket. I am in the Southern CA area. Do you know of anyone in this area that can help me with the install?
Thank you,
Hey MkcoenCan't help you there. I've got a couple of pulleys for the C7 (which doesn't help me either). I haven't seen a loose one for the 3116. I'm going to see if I can't modify the one I have to work but it's not a direct bolt in.
Posted earlier that I was mistaken and the pulleys were actually for the 3116 (which is lucky since that's what I needed). I have nothing for a C7.Hey Mkcoen
I have a C7 and i need those pulleys. Do you still have them? If so, could you please contact me via pm or cell? 310-628-0724
Thank you
I believe he was referencing the idler pulley. I had posted very early on that I had one and thought it was for the C7 not the 3116 but, as often is the case, I was wrong.I believe the C7 uses the same pulley as I listed based on the post I got the part number from. I had confidence it would fit the 3116 since the damper it mounted to was common between the C7 and the 3116 based on looking at the parts manuals for both engines on caterpillars website. You should be able to verify via caterpillar.
The idler bolts to the A/C bracket so it's not engine dependent.I believe he was referencing the idler pulley. I had posted very early on that I had one and thought it was for the C7 not the 3116 but, as often is the case, I was wrong.
You lucked out you got the last one in the known universe. Cat says no more in the world with no restocking date.Hi. If you haven't found the pulley yet... Call Ringpower corp. They are a caterpillar dealer. I found one for my c7 for only $188.00
