gottaluvit
- 26
- 48
- Bethesda, OH (AKA: Flyover Country)
Will they pass it with the bullet holes in the fender?
Here is the finished product. Took maybe an hour and a half total. I just wrapped the cord nice and tight with the occasional note.
That would be cool if it was in the stickies thanks cucvrus
Symptoms? I'm having issues with mine atmI have wanted to set it on fire the last week or so. I have had to use it as my daily driver and she has been giving me nothing but fuel trouble. Finally after making everything from the tank up new, the last thing it could be is the IP. I have started the swap for an NOS one, will hopefully finish tomorrow.
Are all the fuel tank vent lines clear ? In this warm weather even diesel fuel can start to vapor lock.I have wanted to set it on fire the last week or so. I have had to use it as my daily driver and she has been giving me nothing but fuel trouble. Finally after making everything from the tank up new, the last thing it could be is the IP. I have started the swap for an NOS one, will hopefully finish tomorrow.
I would pay good money for those. Never learned how to do that stuff.Here's some more paracord for you. Did one of the grab handles.
Looks good, NOW get rid of that chrome !!!Here's some more paracord for you. Did one of the grab handles.
YouTube will give you a jumpstart.I would pay good money for those. Never learned how to do that stuff.
Sent from my SAMSUNG-SM-G870A using Tapatalk
I may sound like a cracked record but a rebuilt injection pump will correct a lot of ills on any CUCV that is running poorly. I always change the lift pump when I buy a CUCV and they are usually past due and full of crud. Today I picked my Crown of Thorns M1009 up at the GMC truck dealer. It was there for Pennsylvania State Inspection and passed with no issues. It has 124K on it and will be on the road for years to come.Total cost of Pennsylvania State inspection was $32.81 Not bad for a 30 year old truck. And I always take it to the GM dealer. I want it to be safe. No corners cut on safety when you are driving your entire family down the road on occasions. I have to get out on my cab removal project.I would be driving along, then it would loose power, smoke grey/blue, then pick up again. Or die if jt happened while slowing down. Or just die outright. New sending unit/pickup, all new rubber hoses, upgraded filter.
I had it torn most of the way down to change the IP, when I decided to try the fuel flow test in the TM. It was low. I had put an inline electric pump in when it wouldn't run at all due to no fuel to IP. Drove it for a day like that, then symtoms returned, but not exactly the same. Decided to go back to stock lift pump, and put it all back together. Runs good except there is air in the fuel, it hiccups, acts like I am pumping the accelerator, but no smoke or dieing. Rechecked all the lines, I have a new lift pump I plan to put on this morning.
I just used a slip knote when I started, clinched it down very tight and then at the end I just did a regular knote and also tucked it under a couple times. Then I trimmed he tail off as close as I could get it, headed with a lighter and mashed it into the other strands of rope. It seems to hold good and tight that way. I drove ge truck again this morning and it still is holding up.I'm seriously considering doing the same to my M1009. Could you please explain how you secured the paracord when you started? What knot(s) did you use to tie it off at the end of the top and bottom sections?
How hard of a ride do you want ? The stock springs will give a pretty hard ride but add an extra leaf and it will be really hard ! Now if you have a heavy plow up front then go with the 4 leaf springs. If not I would stick with the stock 3 leaf spring set-up.Got to use the truck to pull my other truck across the property the other day, in the process of a engine rebuild with that one. I'm starting to stock up parts for the truck, fuel tank and rear drums shoes etc are on the way, still have to get king pins u joints and all the other stuff for the front axle. I usually have 3 days off a week so I'm hoping to get all of this done at once due to it being my DD. After this is all finished I'm going to get the injection pump rebuilt just to be on the safe side. Other than all of that I'm painting the frame and getting ready to change the fluid in the trans and t-case, after seeing what the gear oil looked like in the axles I can just imagine what this is going to look like. Still trying to figure out which leaf springs I want to go with in the front, I have been considering the replacement 4 leafs that you can get and put on.
I just love your landscaping. The well placed lawn ornaments is genius! I need more squares for my place.View attachment 636483It is easier to change springs if you tear it down this far. It makes everything easier to change, clean and coat with paint. But i will be posting the rebuild on the Easter find M1008 thread if you are interested. New 4 ply front springs are on the agenda. Stay tuned.
Now that looks great; real nice.Finished wrapping the steering wheel of my burban clone. Took just under 100' of cord.
