- 1,199
- 455
- 83
- Spartanburg,SC
After wanting to try this for some time, I finally got it accomplished this weekend. I contemplated installing it several ways but this seemed to work just fine and wasn't too much trouble. I ordered a 4 door central lock kit remote control conversion from Amazon and 2 barrel bolt locks. Around $30 total. The pictures should explain how everything went in. I added a safety to unlock the doors from the inside just in case the Chinese made actuator decided to quit while in the truck.
This is how it's mounted but flipped and installed on the inside of the door. I welded a nut on the end to connect the actuator.
This is my safety override wire in case someone gets locked in with a bad actuator.
Installed and complete. Just drill a hole in the door jamb and install the cover plate.[h=1][/h]
