racing4funn
- 0
- 16
- Chattanooga Tennessee
Out of the four trucks ive had my hands on, they all have zero movemen. They are locked to do whatever the engine does. Is this the intended design?
are you talking about removing line from the shutterstat air actuator ? if so top or bottom line coming from shutterstat?My 91 had a stuck fan when I got it. You can tell by the noise it makes over 40ish, sounds like your getting buzzed by a prop plane. I disconnected the line from the solenoid and blew compressed are down the line until the fan moved back and forward, engaged and disengaged. Wrap a rag around the line before you blow air down it, otherwise you'll get a power steering fluid shower like i did.
If the fan moves as it should and it still stays engaged then you have something else wrong up the line like maybe a bad solenoid, check ps fluid level also.
Matt
In the HMMWV world, there is no such thing as a shutter gate....whatever that is.are you talking about removing line from the shutterstat air actuator ? if so top or bottom line coming from shutterstat?
Some guys have mentioned that their fan will not turn with the engine off.
I was just thinking....Would it make a difference if the fan was engaged or not at the time the engine was shut off?
That could be something for one of you to check.
Post #4:I just love guys that can only give smart a## answers.
