gimpyrobb
dumpsterlandingfromorbit!
- 27,785
- 749
- Cincy Ohio
Thats is the old series of 5ton steering.
If it has a dump and the steering is like that picture then the truck is a M54 series 5 ton with the LDS multifuel engine.Thanks guys for the answer, sorry for the slow response, but that opens a lot more questions. Here they are: this truck does have a dump body, does that mean it is a 5 ton, and if it is, what model truck would it be. I won't be able to see this truck for another week or so to get a picture. If it is a M35 with 5 ton steering, is this a common upgrade, is it a good setup? And what does the newer 5 ton steering look like? Thanks again
800 series used cummins not multi, it would be an m51.If it has a dump and the steering is like that picture then the truck is a M800 series 5 ton with the LDS multifuel engine.
I think he mentioned it was a dump. M54?800 series used cummins not multi, it would be an m51.
My bad, your right. Will correct post.800 series used cummins not multi, it would be an m51.
