I'm combining two rims to make a 12" wide rim with the 11.25 bolt circle. The dish part is from an MRAP (Hutchison- black with primer) with the correct bolt circle and the outer ring from the rims that came on the 450 Sand Trail tires (tan). The (20) rim bolts all are the same but the ring bottoms out where the o-ring goes. The o-ring needs space (I measure a 1/8" gap on the Hutchisons at the top).
I can't find a lathe with enough bed capacity to chuck up the ring and remove about 1/4", which will leave 1/8" opening for the o-ring. And it has to be about 10 degree.
Does anyone have any ideas on taking that much (1/4") off and making a 10 degree angle?
I'm thinking about making some kind of a grinder attachment but hoping for a better solution. Any ideas?
