Installing air ride seats in 931
roalcoal
poplarville ms
Thanks to floridianson for hooking me up with these great seats! I finished up my install today. I removed the battery box and moved the batteries to the tool box under the passenger side, made my bases out of 1/8 plate and 3" c channel everything worked out greatIMAG0367.jpgIMAG0368.jpgIMAG0379.jpgIMAG0377.jpgIMAG0376.jpg
MtnSnow
14
NSL, UT
What kind of suspension do those seats have? Edit...Let me clarify. How much LIFT/Drop does these seats have?
Floridianson
2,503
Interlachen Fl.
They come out air up real close to what a springer seat is when you sit on the springer.
On the air ride you can use the yellow latch to raise or lower the seat about one and a half inches when it is aired up. So with the latch latched and the seat aired up it is around 13 inches to the base and when you unlock the latch it is around 15 inches high.. These should be able to go in Deuces. 809 or 939 series with a base built to fit your butt.
Plane Fast
Panama city FL
I started my install yesterday! It was late so, no good pics. It's in my M923a2.
Same HEMTT seats as yours. I have one more, that I'm going to sell.
Nice job on the install!
Gunny65
Bonners Ferry, idaho
Nice install. I want to do this as well but I want air ride seats with arm rests. Arm rests seem to add an inordinate amount of money to the purchase price. Oh well. This isn't a cheap hobby. Anyway, love the look and congrats on the seats.
simp5782
Feo, Fuerte y Formal
9,476
Mason, TN
How did you anchor the bases and seat belts?
My seatbelts hooked to the seat themselves. I used some 3/8in angle iron i has laying around for bolting the seat thru the cab and into it. I then welded some angle iron from the front angle to the rear angle iron.
Sent from my SM-G860P using Tapatalk
grendel
12
Derry, NH
Where did y'all hook up your seat air bladders? I found constant air underneath on the frame, but would like something in the cab.
Floridianson
2,503
Interlachen Fl.
If you have a 939 series there are three air fitting on the floor board next to the drivers seat. The fitting closest to the rear of the cab is a air supply.
