Probably has one piece run-flats. Everybody with a HMMWV or M1102 is in need of the same thing (that don't want to run with run-flats). They look just like the 20"x 11" that I have but are 16.5" x ?.Kascar has the one pictured above for $408.52. Just make some from PVC. What is wrong with the 1-piece beadlocks that are in your tires?
If you have some spare beadlocks for the 16.5", I need some too.i meant to say runbflat / beadlock. I know what they are. I have installed and removed many of them. With the proper tool, you can put one in in under 15 minutes.
Do a web search. They are already made.If you have some spare beadlocks for the 16.5", I need some too.
How do you make one from PVC? Is there a size that fits correctly to the HMMWV 16.5" rims?
Thanks for your help. I will.Do a web search. They are already made.
