Ted Nugent (rocks)I think there is damage in transfer case. /maybee someone put in low and smashed the gas petal in reverse that might do it.
The dredded loose screw between the seat and the steering wheel!Thanks for your input,it's up and running),it was some electrical short between the gear lever and the transmission.
This guy has good advice. Only a couple things that can cause the engine in a auto to stall is a torque converter clutch being engaged for some reason. Or a fuel problemButton on the transfer case shift lever may be stuck.... this is the kind of weirdness that will cause.
Or you may have a fuel issue. Sucking air in the fuel line or a clogged filter can cause it to die when put in gear.....
Down in the south a barn is just as goodIt would quit if you took it to a motel.
