- 1,037
- 1,854
- WOBURN. MA.
Same here, I'd like to see closeups, I have a set of troop seats sitting in my garage.congrads & looks sharp!
Can you post more pictures inside and out of the cut down troop seats as I am tempted to do the same. Does the rear cargo cover fit with them on?
I do have the rear cover and bows from the 2 man setup and 4 man setup. From my research the 2 man bows need to be cut down for height and also have 1 1/2" removed from the center section for the cover to work properly. I have new seat belts for the troop seats and will be installing smaller eye bolts on the fender wells so I can use quick disconnects for the seat belts. I am also going to replace the wood slats with possibly some of that composite decking material from Home Depot and painting it Pinz green. Already have antenna offset mounts to put the antennas outboard of the troop seats. Lots of little projects ahead of me and will be picking up X doors over the winter.congrads & looks sharp!
That's true and a better choice...Thank you.newer troop seats are fiberglass. you might find some of those cheap.
