coachgeo
- 3,462
- North of Cincy OH
For those with 6x6.... these should fit your rear most axle cause the innards are the same. For the Intermediate axle... not sure. There is a standard Ring and Pinion behind the offset box that goes into the pumpkin like any other axle per manual image*... the part numbers for things between the models are similar... but not the same. Interesting. Maybe someday we can get side by side pics to help discern the differences. Green shows units with same part # but all the others are similar between 4x4 and 6x6...... but not the same exactly (by numbers)
6x6.........................................vs.....................4x4
note: bold underline shows where the numbers slightly differ between the two
Pinion Gear ..... A-41631K2 ......... vs ...Pinion Gear ..... 41633K2
Int. Axle Ring... A-41100K2......... vs ... almost same as 4x4 rear / with 6x6 being ...00K2 and 4x4 ...02K2 as shown below
rear Axle Ring.. 41102K2-1.95..... vs ... rear axle Ring.. 41102K2-1.95
* images and part #'s from manual pages of:
LMTV Rear Axle image and and part numbers from...... TM 9-2320-365-24P pages 374-376 (section II, Group 1102, Image 135)
MTV Rear Int " " " ..................."..........."............... TM 9-2320-366-24P-1 pages 499-505 (Section II, Group 1102 Image 162)
MTV Rear Most " " ................"................"............. TM 9-2320-366-24P-1 pages 494-497 (Section II, Group 1102 Image 161)
