Adding A/C too, I see!
Already had it just wanted to show the kit in case anybody needed to know what is was with this inter cooler everything fit great including the condensor and fans in front of inter cooler. Gun a run her tommorrow a see if temps will drop.
FINGERS CROSSED!
Here is some part numbers;
Summit Racing Part Numbers-
VPE-2630= 3 to 2.5 reducer input to intercooler
VPE-2632= 4 to 3 reducer input to intercooler
CEL-61323= Lower radiator hose (after you mod top tube so it can rotate) by tempstat
CEL-64312=Back of block 180 degree 3/4" heater hose that eliminates tubing that was going to aftercooler
DEP-420048= 4" stainless exhaust tubing
DEP-524521= 45 degree 4" tubing you need 2 of them.
FLO-MB125048= 2.5" tubing for lower radiator and turbo out
SUM-622118= 90 degreee 2.5" tubing you need 2 of them for lower radiator and turbo out
Mc Master Carr
5591K86= 4" Blue High temp hose 350 degree, with a 4-3/8 od I bought 6 feet but about 3 is all needed.
5591k56= 2.5" Blue high temp hose 350 degree, with 2 7/8 od I bought 6 feet but only 2' is needed.
Gov * or whoever
radiator NSN 2930015576211 which is about 28 tall has intercooler 4" ports , oil cooler which has 3/4 NPT ports and Radiator
Cummins or any vendor
Intake manifold- 3925453 = you have to cut tube connection and rotate 90 degrees counter clockwise the re weld !
Well thats it for now, Marty
