hmmwv tow bar
2deuce
154
portland, oregon
Does anyone have one of these mounted on your HMMWV and could give a few pics on how it attaches? Can you use it with the folding grille guard?
Thanks
Lawdog734
101
Colbert, GA
Which one? There's the old school medium tow bar and then there are the lightweight Ibis Tek ones, which I believe have 2 different types mounting.
I've got an Ibis Tek version but I won't be able to get any pics until this weekend.
juanprado
2,922
Metairie/La (N'awlins)
The other solution is to use the 3/4 feet from the oshkosh square tube tow bar with the tan aluminum biscuits as that is how I think it packaged as a "kit"
I have a set of those feet with all the pins. PM if interested. MWMULES was selling the biscuits very reasonable. http://www.steelsoldiers.com/showthread.php?155353-Ibis-Tek-Tow-bar-biscuits-adapters
The picture previously is of the medium round tow bar feet. Not sure if the foot has been modified/bushing as i thought it was a different diameter.
1 Patriot-of-many
86
Zimmerman MN
Anyone have a picture of how the biscuits are used?
juanprado
2,922
The small pointy hole of the biscuit goes into the black 44lb tow bar. It uses the pin from the tow bar. The foot Y with the wide 1-1/2 pin is on the other side of the flat biscuit. ( pic below the bigger pin is sideways and you don't see the opening). The smaller side of the foot is 3/4 and attaches to the mount on the HMMWV
Recovry4x4
LLM/Member 785
1,808
GA Mountains
Informative thread even for those who are sans HMWWV. My question from the outside looking in, are the HMMWV tow shackle anchors available? They look somehwat useful on another project I have.
MWMULES
349
DESOTO, KANSAS
Do you have a picture of the feet on the tow bar?
Just want to make sure I do it right.
No biscuits or grinding needed if you have the tow bar you pictured in post #11 , then you do not have to do anything as long as you have the 3/4' feet shown in #3 as they will fit that tow bar without grinding. Grinding of the feet or using biscuits is only needed when using the big Black Ibis Tek 44,000lb Medium_Tow_Bar.jpgtow bar with the older Green 3/4" or 1" pin feet.
juanprado
2,922
