TruckGuy
- 24
- 18
- Belmont, NC
So I go to put the TC in neutral to rotate and get to the u-joint grease fitting. Won't budge. Find out that part of the linkage is seized.
Any of you had this part of the TC linkage seize up? The TM show it as just a shaft going through the c-channel. My has a pipe welded in the c-channel with the shaft running trough it. I can get it to turn with a 3ft pipe slipped over the arm... barely. Have been soaking it with PB blaster, just can't get it to loosen up.
