- 3,197
- 3,171
- NORTH (Canada)
My Deuce is definitely female and she always finds something irritating to do. Latest kink is that both headlights come on with low beam when the truck is first started. After a few seconds the left headlight goes dark. It works fine when high beam is selected but immediately goes dark on low beam.
When I unplug cable #17 (high beam) at the headlight, the low beam comes back on and stay on. Obviously high beams wont work without the connector plugged in.
The right headlight works as it should.
Any ideas why the headlight works with high beams disconnected but wont work with the connector plugged in? Light switch or high beam switch issue?
