I want to bob my A3 and leave the frame full length, then go to 395's or maybe 14.00's or...I bought some of the 450/80/r20 Sand Trail tires and I'm wondering about using them.
They have a steel wheel, 1/2" thickness that I can easily make a weld in adapter to fit the 6 lug (or the ten lug). It would pilot on the front ring, which is 15 5/8".
I would like a tool box (Job box) in front of the bed, which will be an M105. I expect to use the frame section with springs also from the trailer .
These 450's are the same od as a 14.00, but 16" of tread width. I could also use the 14.00 NDCC pictured (I have 7 new ones). And I have chains that fit the 450's.
What do you think about that big Sand Trail tire on an A3 deuce 4x4 ? By the way, the machine they came from is rated to go 50 mph.
